AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Exporting shp file from AutoCad Map 3D 2012 x64
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Started having a problem when I export out a line in AutoCad to a shapefile. ArcMap can't open because the files don't match and whne I try to read it in AutoCad, I get the same basic message.
There was a problem accessing the connection's schema information.
The file 'L:\REFERENCE_MATERIAL\New-Connects\BTMR-08-02-TEM
Re: Exporting shp file from AutoCad Map 3D 2012 x64
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would be careful using 14 characters as filename for a shape (it 's an very old styled format, used in times for dos with 8.3 filename-structure).
Then you should always remove the IDX-file if you transfer SHP-data between different software-packages.
And just to make sure, there are some applications that see differences between lower- and uppercase-characters in the filename. So if you have a file A.SHP, a.shx and a.dbf ==> the files are not recognized to belong together, they have to have the same letters for all three filenames (at least 3 files).
- alfred -
Alfred NESWADBA
