• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    bingeomatics
    Export to Shape
    342 Views, 12 Replies
    08-28-2012 10:47 PM
    Hello, colleagues!
    How can to export my SDF file to ESRI Shape file? In AutoCAD Map menu have a commands, but those works only for drawing objects. Have any way to export SDF to Shape?
    Thanks all? who can help me!
    Binnat Khalilov
    Please use plain text.
    Re: Export to Shape
    08-28-2012 11:10 PM in reply to: bingeomatics
    two options:
    • use _MAPIMPORT (>>>details<<<) to import the SDF-file (don't forget to import the attributive data to objectdata .... and then use command _MAPEXPORT (>>>details<<<) to create a SHP.
    • use _MAPCONNECT to get the SDF referenced into your drawing. Then create an empty SHP +the structure for it (using schema-creation functionality(>>>details<<<)). When this part is finished you can use bulk-copy (>>>details<<<) to transfer the content from SDF to SHP.
    Good luck, - alfred -
    Alfred NESWADBA
    bingeomatics
    Re: Export to Shape
    08-28-2012 11:26 PM in reply to: alfred.neswadba
    Thank you very much!
    Binnat Khalilov
    bingeomatics
    Re: Export to Shape
    09-12-2012 04:19 AM in reply to: bingeomatics
    Hi!
    I tried to copy from SDF to SHP, but I can't. When I can't apply  Bulk copy command? What problem must be?
    error
    Binnat Khalilov
    Murph
    Re: Export to Shape
    09-12-2012 02:55 PM in reply to: bingeomatics
    A SDF file can contain point, line and polygon features all in the same dwg. Most likey your SDF is set up as multiple type features. You might want to try FDO2FDO from SL-King its a little more forgiving.
    http://www.sl-king.com/fdo2fdo/fdo2fdo.html
    Murph
    Supportting the troops daily.
    bingeomatics
    Re: Export to Shape
    09-12-2012 09:48 PM in reply to: Murph
    Thanks, Murph! I will try...
    Binnat Khalilov
    bingeomatics
    Re: Export to Shape
    09-12-2012 10:00 PM in reply to: bingeomatics
    Murph, thanks, it works goog, I have exported and finished sucsessfully. But it don't exports coordinate systems informations. How can I solve this problem. Did you used FDO2FDO?
    Binnat Khalilov
    Re: Export to Shape
    09-12-2012 10:54 PM in reply to: bingeomatics
    the coordinate system is stored in a separate PRJ-file (same name like SHP, DBF, SHX, but other extension).
    If you don't have that file and you need it, create an empty shape winthin a drawing with assigned coord-sys, that will also create a PRJ-file then. Use this file and rename it to the name of your SHP-data.
    To the above message: I have seen that also when converting an SDF or SQLite to a SHP even when the sources where set to a single geometrytype (POLYGON) and not multiple-geom-types.
    - alfred -
    Alfred NESWADBA
    bingeomatics
    Re: Export to Shape
    09-12-2012 11:26 PM in reply to: alfred.neswadba
    Thank you, Alfred.
    Binnat Khalilov
    bingeomatics
    Re: Export to Shape
    09-12-2012 11:27 PM in reply to: bingeomatics
    But I want to know, is it that I did wrong anything in AutoCAd Map while exporting?
    Binnat Khalilov
