AutoCAD Map 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Murph
Re: Export did not succeed
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
07-08-2008 11:48 AM in reply to:
monkey5672
Looks like there is an object (point type) way outside of the coordinate
systems extents. Does a zoom extents zoom way out? Turn Qtext on and zoom
extents there may be a null text object out there in wonderland.
Murph
www.map3d.wordpress.com
"monkey5672" wrote in message news:5976176@discussion.autodesk.com...
Checking my acadmap.log file ... there are a bunch of entries from this
morning, all pretty much alike. The only difference among them is the Handle
ID. Example below:
AutoCAD Map Error : 1 - Can't perform datum conversion.
AutoCAD Map Error : 1902 - Can't transform object.
Diagnostic parameters:
LWPOLYLINE - handle A1E
Murph
ID. Example below:
Options
- Highlight
- Email to a Friend
07-08-2008 12:00 PM in reply to:
monkey5672
Negative on that one. I'm going to take a look back at my DLLs. I was trying to get FDO support for PostGIS working, and I may have changed the shapefile prodiver as well. I wonder if that may have done it?
Options
- Highlight
- Email to a Friend
12-19-2008 11:56 AM in reply to:
monkey5672
I am having the exact same problem.
Yesterday it was working. Now I get the Export did not succeed message.
I am using Map 2009.
Any solutions?
Any solutions?
Options
- Highlight
- Email to a Friend
01-23-2009 12:12 PM in reply to:
monkey5672
Hi, I've had this problem several times in Autocad Map 2008. It seems every time I try to set up an FDO for postGIS, my Mapimport/Mapexport gets screwed up. I either have to do a full re-install (usually fixes everything), or a repair (fixed import the last time, but export is still busted).
I couldn't begin to explain why, but its a pretty annoying occurance.
I'd imagine the FDO connections work better in 2009. Anyone else have similar experiences?
Thanks, -jason m.
Thanks, -jason m.
Options
- Highlight
- Email to a Friend
06-05-2009 12:32 PM in reply to:
monkey5672
Hey. I just had some "Export did not succeed" messages. Tried a bunch of things, then read this thread and mapexport4 worked, then through map tools export saving to another folder worked and now the map-tool-export works to the folder I initially targeted.....don't know why it worked but it did....
Options
- Highlight
- Email to a Friend
11-04-2009 12:17 PM in reply to:
monkey5672
AutoCAD Map 3D 2010
We were having the same issue "Export did not succeed"
We successfully used MAPEXPORT4 but couldn't select all of the object data from multiple tables.
The very next command we used was the standard MAPEXPORT. We chose all of the data we initially wanted and it worked.
I guess we had to teach Map how to do it the old way before it would have the confidence to do it the new way?!?!
Options
- Highlight
- Email to a Friend
04-13-2010 11:56 AM in reply to:
monkey5672
AutoCAD Civil 3D 2010
Same problem here. "Export did not succeed."
Turns out the issue was trying to export to a folder that was too crammed with other files. Created a new folder, exported to that, and it worked.
Options
- Highlight
- Email to a Friend
04-14-2010 08:34 AM in reply to:
monkey5672
I went through all of this last week. I don't want to blame Map2011 but my shape export stopped working (in 2010 and 2011) right after after installing it.
I tried re-installs of all my Autodesk and ESRI products but couldn't get it working again. I finally had to do a complete, clean uninstall of all ADESK stuff and then put Map2011 back on to get my shape export back. It seemed a little heavy handed to me but in a mixed Autodesk/esri shop I had to get it working again.
Options
- Highlight
- Email to a Friend
09-13-2011 02:31 PM in reply to:
Gary_Braun
After recently installing Map3D 2012, "Did not Succeed" happened to me.
Thanks to seeing a post on this thread, I tried creating a new folder with nothing in it... then it magically worked!
Options
- Highlight
- Email to a Friend
09-10-2012 04:33 PM in reply to:
toddc
Lol ToddC, same here. worked fine once i went to a new folder.
Using Civil 3d 2012, had the same problem. Folder cluttered with other shape files can't be exported to for some reason!! what the hell.
Additionally mapexport sucks at exporting closed polygons!
