• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Accepted Solution
    Export SDF to ASCII /or XLS/
    219 Views, 4 Replies
    01-02-2013 10:57 AM
    Using Civil 3D 2012 x64
    I have an SDF file which contains point objects with associated data table records
    I'm trying to extract the data to xls file /or text file/
    Once imported in Map there's the option to view data table, then one can go select all and copy/paste everyhing in excel
    This would have been perfect if coordinates were exported too. Alas I end up with a rather useless table
    Is there a way to convert an SDF file to xls file and preserve all the data records along with the geometry /xyz/ in the process?
    for something SO BASIC there HAS to be a basic solution
    Thanks in advance!
    Please use plain text.
    *Expert Elite*
    Re: Export SDF to ASCII /or XLS/
    01-02-2013 11:10 AM in reply to: todor.latev
    If you have not "imported" the SDF, but connected to the SDF, then you can create calculated fields as additional columns to the datatable. Then you can export again (or use copy&paste) to get a XLS including the coordinate-values.
    (hope this video is a help, even it's German, if not, let me know)
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    New Member
    01-02-2013 11:31 AM in reply to: alfred.neswadba
    Thanks Alfred, this worked!
    Never seizes to amaze me though how simple things like this have to be researched and worked around to accomplish...
    BTW - is there a way to use excel as an SDF viewer/editor?
    Cheers,
    Todor
    *Expert Elite*
    01-02-2013 11:41 AM in reply to: todor.latev
    As Excel is no GIS-tool/has no GIS-functionality, I don't think so.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    01-03-2013 12:45 AM in reply to: alfred.neswadba
    you can import SDF with MAPIMPORT command and convert attributes data to OD.
    Then you can export to SHP file with MAPEXPORT command. You can export OD AND AutoCAD properties like geometry (X,Y,Z,length, area, rotation...), layer, color... to attributes data
    In SHP format, attribute data are stored in DBF file which can be opened and viewed by Excel. But don't modifiy and save back the DBF, because you can damage structure of data.
    Olivier
