AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Export SDF to ASCII /or XLS/
- Highlight
- Email to a Friend
Using Civil 3D 2012 x64
I have an SDF file which contains point objects with associated data table records
I'm trying to extract the data to xls file /or text file/
Once imported in Map there's the option to view data table, then one can go select all and copy/paste everyhing in excel
This would have been perfect if coordinates were exported too. Alas I end up with a rather useless table
Is there a way to convert an SDF file to xls file and preserve all the data records along with the geometry /xyz/ in the process?
for something SO BASIC there HAS to be a basic solution
Thanks in advance!
Re: Export SDF to ASCII /or XLS/
- Highlight
- Email to a Friend
If you have not "imported" the SDF, but connected to the SDF, then you can create calculated fields as additional columns to the datatable. Then you can export again (or use copy&paste) to get a XLS including the coordinate-values.
(hope this video is a help, even it's German, if not, let me know)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
Thanks Alfred, this worked!
Never seizes to amaze me though how simple things like this have to be researched and worked around to accomplish...
BTW - is there a way to use excel as an SDF viewer/editor?
Cheers,
Todor
- Highlight
- Email to a Friend
As Excel is no GIS-tool/has no GIS-functionality, I don't think so.
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
you can import SDF with MAPIMPORT command and convert attributes data to OD.
Then you can export to SHP file with MAPEXPORT command. You can export OD AND AutoCAD properties like geometry (X,Y,Z,length, area, rotation...), layer, color... to attributes data
In SHP format, attribute data are stored in DBF file which can be opened and viewed by Excel. But don't modifiy and save back the DBF, because you can damage structure of data.
Olivier
