• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Accepted Solution
    Export DWG text objects to SDF but how to label them ??
    284 Views, 4 Replies
    09-18-2012 07:17 AM
    Map 2012
    How do I add text labels to points?
    I'm exporting DWG objects to a SDF file. Once connected to the SDF file, text items are displayed as points as expected. I have ensured the STRING attribute is present in the conversion and I can see these values in the Properties pallete.
    I want to label the points using the Style Editor but try as I might no text label appears. I've checked the obvious stuff like ensuring I'm not using black text on a black background and the text is not so small that I cannot see it.
    I can label lines so I know I can do it!
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Export DWG text objects to SDF but how to label them ??
    09-18-2012 07:45 AM in reply to: toolbox2
    Instead of _MAPCONNECTing it, try to _MAPIMPORT the SDF, setting up as the attached one...
    Valued Contributor
    09-18-2012 09:20 AM in reply to: antoniovinci
    Thanks, but I don't want to re-import something I've just exported.
    If it comes to it then I'll have to XREF in text objects but surely there's a way to label them ??
    *Expert Elite*
    09-18-2012 11:33 AM in reply to: toolbox2
    have you activated the "object-label" property in the stylization-dialog for the SDF?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    09-19-2012 01:40 AM in reply to: toolbox2
    I'm a dummy. I was trying to label a line or polygon, not the point. Thanks for the help, your screenshot showed me my obvious mistake.
