AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Exeception errors when opening and closingfil es
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello everyone,
This is my first time to post on this forum :-)
I am no expert in AutoCAD Map3D, but as a IT Technician, I am responsable for installing and configuring the application.
I just did an upgrade from AutoCADMap3D 2012 -->2013. For the two users that I did the installation, they have been getting this error "Exception in command ARX covsrvechelle19.arx" screenshot attached.
The dxf file they are trying to access is on the network drive. With Map3D2012 they have never experienced this problem. I installed AutoCAD SP1 but the problem still persisted.
Please advice !!
Thanks in advance,
Re: Exeception errors when opening and closingfil es
- Highlight
- Email to a Friend
You can't install a servicepack for AutoCAD on top of AutoCAD Map3D, didn't you get an errormessage when trying this?
Or have you installed the SP1 for AutoCAD Map3D (as the current SP for AutoCAD is known as SP1.1?
Does the problem only appear with that single file? If so: open it with 2012, save it as DWG and open the DWG then in 2013.
So you have such a file on the system? Because I don't have that file. And that makes me guessing you have installed apps or applications on top of AutoCAD ==> which one? Also try to start Map3D with a profile that does not load these apps/applications?
Goos luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
hi alfred,
thank you for your response.
As for the service pack, I actually installed SP1 for AutoCAD Map3D:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
>>Does the problem only appear with that single file? If so: open it with 2012, save it as DWG and open the DWG then in 2013.<< I will confirm with the users.
As for the ARX covsrvechelle19.arx file, our users are using AutoCADMap2013 with Covadisv13. We previously had Map3D2012 and Covadisv12
I will confirm with the users to use AutoCADMap3D without Covadis.
- Highlight
- Email to a Friend
efyuze wrote:As for the ARX covsrvechelle19.arx file, our users are using AutoCADMap2013 with Covadisv13. We previously had Map3D2012 and Covadisv12
Make sure the Covadis is the current version and all updates/patches are installed. My French isn't that great but it looks like there is an patch/SP for it out there.
Supportting the troops daily.
