• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Map 3D
    New Member
    Excel Co-Ords
    91 Views, 5 Replies
    12-13-2002 09:30 PM
    Hi This is my first post and I'm Very New to AutoCAD
    I'm an engineer and need to turn an AutoCAD drawing into an excel spreadsheet
    what I need is to lift the Co-Ords from the centre of Circles and turn them into a spreadsheet which looks like this
    P10 2064.800 2001.050
    P11 2065.700 1999.475
    P12 2063.900 1999.475
    P13 2072.000 2001.050
    P14 2072.900 1999.475
    P15 2071.100 1999.475
    Where P15 is the Name of the point and the first Co-Ord is Easting and the Second the Northing
    i need to do about 5000of these so doing them by hand is tiring and dangerous as i'm bound to miss type one
    It would also be hand to do the same but the other way around, so i can constuct an Asbuilt drawing from an excel spreadsheet
    Thanks in advance I hope someone can help
    I can Email copies of drawings or Spreadsheets if need be
    Neil
    Please use plain text.
    *Gazit, Arad
    Re: Excel Co-Ords
    12-13-2002 11:00 PM in reply to: NWhite
    Neil hi,
    Autodesk Map can do this quiet easily. I don't know
    if you have this program, but you can send me your file and I will send you back
    an ASCII text file which you can import into Excel.
    Try sending a small dwg (Only the needed
    objects).
    Arad
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Hi
    spreadsheet
    P11
    2065.700 1999.475
    P14
    2072.900 1999.475
    Second the Northing
    Neil
    *George
    Re:
    12-14-2002 02:07 PM in reply to: NWhite
    I am very interested in how you can do that.
    I do have Autocad 2000 map. Can you please tell me also.  I need to have
    all the points exported to excel.
    Thank you
    Neil hi,
    know if you have this program, but you can send me your file and I will send
    you back an ASCII text file which you can import into Excel.
    objects).
    Arad
    Hi
    spreadsheet
    P13 2072.000
    2001.050
    Neil
    *Gazit, Arad
    Re:
    12-15-2002 01:11 AM in reply to: NWhite
    Hi George,
    To make a long story short:
    1- Open a new, empty drawing and attach your file
    to it.
    2- Define a query that will return only the wanted
    objects (Use any of the criteria you need: Layer, object type, location, data
    3- Execute the query in Report mode and define in
    the report the information you want (X, Y, Z, Block name, Size, scale, attribute
    4- Open your report file (An ASCII text file) with
    your favorite editor/spreadsheet and complete your report (Statistics, Formating
    Good luck,
    Arad
    that.  I do have Autocad 2000 map. Can you please tell me also.  I
    need to have all the points exported to excel.
    Thank you
    Neil hi,
    objects).
    Arad
    Hi
    spreadsheet
    P13 2072.000
    2001.050
    Neil
    *George
    Re:
    12-15-2002 01:25 PM in reply to: NWhite
    I'm sorry I dont get it.  Attach which file to
    the new drawing? Where does Excel come into play?
    Can you please elaborate a little more.
    Sorry and thanks.
    George
    Hi George,
    to it.
    wanted objects (Use any of the criteria you need: Layer, object type,
    location, data ...).
    attribute ...).
    with your favorite editor/spreadsheet and complete your report (Statistics,
    Formating ...).
    Good luck,
    Arad
    Thank you
    Neil hi,
    don't know if you have this program, but you can send me your file and I
    will send you back an ASCII text file which you can import into
    Excel.
    objects).
    Arad
    Hi
    spreadsheet
    P10 2064.800
    2001.050
    P13
    2072.000 2001.050
    Neil
    *Gazit, Arad
    Re:
    12-15-2002 03:41 PM in reply to: NWhite
    O.K. George,
    It was a bit short-hand but I guess some basic
    training will help.
    I will try and clarify what you asked:
    When working with Map you can set up a "Work
    session" in which you have an open drawing and a set of attached drawings (one
    or more).
    This is done by creating  "Drawing set". I am
    not going to get into this here.
    The report you create when Quering objects from
    your "Drawing set" is always a *.txt (ASCII format) file.
    Excel is one tool that can be used to open this
    report file and work on.
    I hope this helps,
    Arad
    to the new drawing? Where does Excel come into play?
    Sorry and thanks.
    George
    Hi George,
    file to it.
    in the report the information you want (X, Y, Z, Block name, Size, scale,
    attribute ...).
    Formating ...).
    Good luck,
    Arad
    I need to have all the points exported to excel.
    Thank you
    Neil hi,
    Excel.
    objects).
    Arad
    Hi
    spreadsheet
    P10 2064.800
    2001.050
    P13
    2072.000 2001.050
    Neil
