• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Lyonstp
    Errors when querying a drawing
    77 Views, 3 Replies
    07-19-2012 06:28 AM
    I'm trying to change the coord system on a drawing. I've gone through the steps properly but when I try to query the drawing content (query all) i get the following "message": "some entities from (drawing name) can't be queried"
    these "entities" appear to be most all of the drawing content less a few polylines. Is there any way to fix this?
    Please use plain text.
    *Expert Elite*
    Re: Errors when querying a drawing
    07-19-2012 06:33 AM in reply to: Lyonstp
    Not all entities can be queried with this functionality, at least only plane AutoCAD-geomtry can be transfered.
    Not allowed are all geometry-types from any vertical products like ACA, MEP, Civil3D, .... and also objects referenced by FDO with Map3D.
    It now depends on the projection-modifications that are done between your source and your destination coordinate-system. If you have the chance to use command _ALIGN to move/rotate/scale your "invalid" objects then you can use this command.
    The other option is not really an option: explode all objects that are not querable back to plane AutoCAD geometry.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Lyonstp
    07-19-2012 06:50 AM in reply to: alfred.neswadba
    hmm, i may have to resort to exploding the C3D objects then. Is there another way to go about changing the coord system on a C3D drawing, one that has C3D objects in it?
    Basically i have a C3D drawing that was done in a local coord system (one thats recognized by C3D) and I need to convert it to a state plane coord system. the tutorial says to go about it by creating a drawing in the new (state plane) coord system, attaching the original drawing and then running a query on the original attached drawing. it was going smoothly until i ran into the problem of not being able to query most of the objects in the drawing.
    Not really sure where to go from here
    *Expert Elite*
    07-19-2012 07:14 AM in reply to: Lyonstp
    You may try to use the LandXmlExport and -import functions to export your current data and import it into a new drawing with another coord-sys (never tried that).
    And yes, Civil3D-drawings do have their coord-sys-setting, look e.g. into dialog for the drawing-settings (>>>details<<<)
    - alfred -
    Alfred NESWADBA
