• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    neil.stapley
    Error message while trying to plot
    314 Views, 4 Replies
    10-28-2011 10:24 AM
    Can anyone help. Every time I try and plot a drawing I get this error message:
    ' YOU CAN NOT USE MULTIPLE INSTANCES AT THE SAME TIME'.  The program then freezes for a short while then returns a message saying plot canceled.
    I am using Map 3D 2011. Although I did have a trial version of AutoCad 2012 I had no problems plotting on both versions up untill recently I have made no changes to any printer configuration, plot files or styles. I removed 2012 after I started getting this message but still I am unable to plot.
    Please use plain text.
    Re: Error message while trying to plot
    10-28-2011 10:52 AM in reply to: neil.stapley
    first I would recreate the PC3 from scratch.
    Then, if that does not work, try to deactivate the variable BACKGROUNDPLOT, do one plot, finish AutoCAD, restart it and reactivate it.
    BTW: what plotter did you use (and what driver)?
    HTH, - alfred -
    Alfred NESWADBA
    Member
    neil.stapley
    10-31-2011 09:41 AM in reply to: alfred.neswadba
    Alfred thanks.
    Setting the background plot to zero (which I am assuming is deactivating it) worked. If the then set it back to 1 it brings back the error.
    Does this give you better understanding on what is going on.
    Neil
    10-31-2011 09:45 AM in reply to: neil.stapley
    Not really, there are some thoughts (plotter-driver, AutoCAD-Map servicepack, ...) but not "THIS" idea to get rid of it ... besides the workaround of turning off BACKGROUNDPLOT.
    Sorry, - alfred -
    Alfred NESWADBA
    Member
    neil.stapley
    11-01-2011 05:49 AM in reply to: neil.stapley
    Thats ok I have it printing now which is all that matters thanks for your suggestions
