• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Map 3D
    Active Contributor
    ESRI Grid
    521 Views, 22 Replies
    05-31-2007 03:02 PM
    Does anyone know how to bring an ESRI Grid into Map 3D 2007. I have a DEM, however it is 10ft and I need a very small area. We have 2ft contours but map crashes when I load them. I used ArcMap to clip the 2ft contour area I need, but I could only save the clip as a grid. I hope my question makes sense to someone :smileywink: Any ideas?
    Please use plain text.
    *James Murphy
    Re: ESRI Grid
    05-31-2007 04:03 PM in reply to: bleestein
    Are you using the FDO data connect to bring in the DEM? You can create
    contours lines and save to a SDF with contours of your choice.
    If that doesn't do it.
    http://www.dotsoft.com/gridworks.htm
    Murph
    The world is not FLAT so why is your GIS data?
    http://map3d.wordpress.com
    wrote in message news:5613063@discussion.autodesk.com...
    *Tripp Corbin, GISP
    Re: ESRI Grid
    06-01-2007 04:53 AM in reply to: bleestein
    Murph
    If I remember correctly Map can not read ESRI's GRID raster format. It has
    been awhile since I tried it though. BTW looking forward to having you come
    down and teach the Map class for some of our folks. Trying to fill a couple
    of extra seats.
    Tripp Corbin, MCP, CFM, GISP
    Associate Vice President, GIS/Mapping
    ESRI Authorized Instructor
    Keck & Wood, Inc.
    www.keckwood.com
    (678) 417-4013
    (678) 417-8785 fax
    Keck & Wood, Inc offers instructor led and virtual training for ESRI's
    ArcGIS & ArcView software.
    Please visit www.keckwood.com for more information including a schedule of
    upcoming classes.
    "James Murphy" wrote in message
    news:5613103@discussion.autodesk.com...
    Murph
    *James Murphy
    Re: ESRI Grid
    06-01-2007 05:43 AM in reply to: bleestein
    No it can't read ESRI Grids but it can read DEM, and Dotsoft has the add-on
    to read ESRI Grids in AutoCAD that works in MAP 3D.
    So anything special you need me to cover or just the basic stuff? What about
    the FDO stuff? The course material I have been using doesn't cover it but I
    can hit the basics in there if needs to be.
    Murph
    ; "GISP" wrote in message
    news:5613444@discussion.autodesk.com...
    Murph
    of extra seats.
    Keck & Wood, Inc.
    www.keckwood.com
    (678) 417-4013
    (678) 417-8785 fax
    upcoming classes.
    Murph
    *Tripp Corbin, GISP
    Re: ESRI Grid
    06-01-2007 07:01 AM in reply to: bleestein
    I definitely want to go over the FDO stuff both shapefiles and personal
    geodatabase. Connecting to WMS servers would also be good in addition to the
    basics. You can expect engineers with LDD and Civil 3D experience and GIS
    folks with ESRI experience. I and one other are really the only one with any
    Map experience and that is getting rusty.
    Keck & Wood, Inc.
    www.keckwood.com
    (678) 417-4013
    (678) 417-8785 fax
    upcoming classes.
    news:5613505@discussion.autodesk.com...
    Murph
    Murph
    of extra seats.
    Keck & Wood, Inc.
    www.keckwood.com
    (678) 417-4013
    (678) 417-8785 fax
    upcoming classes.
    Murph
    Active Contributor
    Re: ESRI Grid
    06-01-2007 08:37 AM in reply to: bleestein
    Thanks for the help, I met my deadline. About FDO, is there anything new on the horizon dealing with ArcSDE 9.2 and Map 3D 2007. Currently we have issues with data not being transported through the Task Pane completely (all "91" files are in place etc.). I test drove AutoCAD Map 3D 2008 and I had to,much to my displeasure, recommend we not upgrade until we could import our SDE data effectively from 9.2. I am excited about some of the changes 08 has, but until we can import, edit, and view attribute/object data tables properly and fully then we have to manage using 07 and SDE 9.2 (also not cooperating properly).
    Distinguished Contributor
    Re: ESRI Grid
    06-04-2007 03:52 PM in reply to: bleestein
    FDO connections can load ESRI grids. I currently have one on-screen that is 540 megabytes in size - a 1-meter grid covering about 120 square kilometers. I have even created contour SDF files from the data with a 0.1 meter interval.
    I just wish Civil 3D could handle even 5% of the data without leaving a smoking crater on my desk.
    *Tripp Corbin, GISP
    Re: ESRI Grid
    06-05-2007 06:25 AM in reply to: bleestein
    That is good to know. Thanks for posting this information.
    Keck & Wood, Inc.
    www.keckwood.com
    (678) 417-4013
    (678) 417-8785 fax
    upcoming classes.
    wrote in message news:5615996@discussion.autodesk.com...
    interval.
    Member
    Re: ESRI Grid
    12-14-2007 03:33 PM in reply to: bleestein
    I have been able to access them as raster surfaces. I have been able to install NED data from usgs. It is very detailed. I can style them but cannot measure or contour them. They apear in 3 day when using 2d view. they disapear when switching to 3d.? Close but no cigar.
    John C
    Member
    Re: ESRI Grid
    12-14-2007 03:35 PM in reply to: bleestein
    Sorry , I just reread your post and saw you were talking about 2007 I am using 2008
