• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    ArmyVet717
    ESC Key and other issues
    175 Views, 2 Replies
    05-25-2012 11:44 AM
    AutoCAD Map 3D 2011 -
    1) Installed the "hotfix" for the ESC key, but it still has issues canceling a command.
    2) When selecting multiple objects, holding "shift" to unselect does not work at all. I have to escape or zoom extents to stop the commands.
    3) Constant freezing when zooming in or out
    I have swapped keyboards, and nothing works. Also happened on another machine prior to installing it on mine.
    Totally at a loss of what to try next. All updates have been applied.
    Please use plain text.
    *Expert Elite*
    Re: ESC Key and other issues
    05-28-2012 12:51 PM in reply to: ArmyVet717
    There was an issue with Photoshop (Elements?) I think. Could it be you have it opened parallel to AutoCAD?
    Are there specific objects selected when <ESC> don't work? E.g. happens only when FDO-objects are selected?
    How is the sysvar PICKADD (>>>details<<<) set?
    Have you FDO-objects active? Can you look to the taskmanager for processor power and memory consumption at this stage (AutoCAD is freezing)?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Contributor
    ArmyVet717
    05-29-2012 06:58 AM in reply to: alfred.neswadba
    We do not run Photoshop. Does not matter what objects are selected.
    SYSVAR???
    FDO??
    It is freezing when zooming in or out majority of the time.
