AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Display order shp files
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have several shp files ordered in the display manager. Three Polygons, one line and one point shp. the problem is that the bottom polygon that is supposed to draw order last continues to show up above all other files during plotting to PDF or other digital file. I have tried to disconnect and reconnect the problem shp, reorder several times but nothing changes. This is making it impossible for me to plot a file in the way is it being displayed.
John
Re: Display order shp files
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try to toggle the "plot paperspace last" radio buttion in the plot dialog. (?) Just a guess on my behalf.
Supportting the troops daily.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can override the Display Manager stack, by means of this nice lisp, sir.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I Could not find a solution and can not spend any more time troubleshooting the problem. I got it to work once through disconnecting all objects and reconnecing in the order I wanted them to display. However, when I went to theme them the problem returned. service pack 1 was installed prior.
John
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JohnPM wrote:I Could not find a solution
I guess you didn't try the above lisp, which physically reorders the layers' stack, sir...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
antoniovinci wrote:I guess you didn't try the above lisp, which physically reorders the layers' stack, sir...
You old LISP does not work with FDO features, FDO display does not use the AutoCAD layers table like you would think.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I Appreciate thefeedback on the display order problem and I also contacted support which recommended REGEN and display ordering. Tried both of those without success. Ended up using an oldschool workaround by attaching the trouble shp as dwg and query..alterprops..hatch..draworder for the same results.. If I find the cause I will post back.
John
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had the same problem, resolved by changing the draw order in Groups and in Draw Order from Task Pan, than right click on the shape/sdf and Refresh Layer (try all, the one you want to have on top refreshing the last), if that does not work than: MAPUPDATEMAP
Ania
