• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    bingeomatics
    Accepted Solution
    Direction of liner feature
    223 Views, 8 Replies
    08-26-2012 10:54 PM
    Hello, colleagues1
    How can I change direction of a line feature? Have any redy  default command to do it?
    Binnat Khalilov
    Please use plain text.
    *Expert Elite*
    Re: Direction of liner feature
    08-27-2012 12:37 AM in reply to: bingeomatics
    if your "line feature" is of type Polyline you can use command _REVERSE
    If your "line feature" is based on an FDO-linked datasource you can select the geoemtry-object ==> right-click ==> and there you also find a point in the context menu like "pline-modify" with the option of reversing the geometry object.
    At least with Map3D2013 it does work in that way. If you don't find the option then let us know what Map3D-version your are working with.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    bingeomatics
    08-27-2012 12:49 AM in reply to: alfred.neswadba
    I am working in AutoCAD Map 2013, but i din't find commant which you sad.....:smileyembarrassed:
    Binnat Khalilov
    *Expert Elite*
    08-27-2012 12:51 AM in reply to: bingeomatics
    if you select the entity, what object-type is it? (what does the property-window show)
    - alfred -
    Alfred NESWADBA
    bingeomatics
    08-27-2012 01:44 AM in reply to: alfred.neswadba
    I have created a liner feature object (sdf file) connected by FDO and created new fature. When I select the feature and press right click, among of the command I dinn't find reverce command.
    Please look at my context menu : Context menu
    Binnat Khalilov
    *Expert Elite*
    08-27-2012 02:16 AM in reply to: bingeomatics
    sorry, the resolution of the screenshot is so small so I can't read your options.
    Look to my video, maybe (hopefully) this is a help.
    BTW: just saw that the option for pline-modifying only appears in the context-menu if the object is checked-in.
    - alfred -
    Alfred NESWADBA
    bingeomatics
    08-27-2012 02:45 AM in reply to: alfred.neswadba
    alfred.neswadba, thank you for the video. But that command in context-menu in you video, I could't find in my AutoCAD Map. Is it additional programm to AutoCAD Map?
    Binnat Khalilov
    *Expert Elite*
    08-27-2012 02:56 AM in reply to: bingeomatics
    No, plain AutoCAD Map3D 2013
    Have you tried first to check-in the feature and then select it and right-click?
    Verify the options if your Map3D is set to automatically check-out features or not. Toggle this option just for a try.
    BTW: just tried: the command _PEDIT should also work on FDO-features, so try the option _REVERSE of the _PEDIT command.
    @Autodesk: why does _PEDIT ==> _REVERSE work on that type of objects and the command _REVERSE does not? Makes no sense for me.
    - alfred -
    Alfred NESWADBA
    bingeomatics
    08-27-2012 03:04 AM in reply to: alfred.neswadba
    alfred.neswadba, thank you very much.....
    PEDIT command have worked.....:smileyvery-happy:
    Binnat Khalilov
