• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    cbarnes1
    Delete Unreferenced & Not Found Excel Xref
    675 Views, 3 Replies
    01-26-2012 11:55 AM
    I copied and pasted special part of an excel document into AutoCAD Map 3D. But I had deleted it instead of detaching it. How do I remove it? Its says I cannot reload, detach or bind. I have 6 of those. I have 2 more that are Not Found and states the same thing. I just want them gone. How do I do it?
    Please use plain text.
    Member
    Re: Delete Unreferenced & Not Found Excel Xref
    02-03-2012 08:16 PM in reply to: cbarnes1
    Try deleting the data link in the data link manager
    New Member
    cbarnes1
    02-06-2012 05:11 AM in reply to: cbarnes1
    Yeah, I had finally figured that one out. I failed to delete or give solution to this discussion once I had found it. Thanks though!
    New Member
    09-12-2012 08:50 PM in reply to: cbarnes1
    the most accurate and the best straight answer ... BULLSEYE!
