• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Expert Elite*
    Joe-Bouza
    Correlate images
    147 Views, 2 Replies
    03-13-2012 08:21 AM
    I correlated several images and exported a world file. When I try to insert the images using the WF in a new drawing the first comes in at the correct location but the remaining file come in at a larger scale but seemingly at the correct location. Could it be because I did not convert to bitonal first? Or what else could it be?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    *Expert Elite*
    Re: Correlate images
    03-25-2012 01:45 AM in reply to: Joe-Bouza
    No, imho it does not depend on bitonal or truecolor or whatever colordepth you are using.
    The world-file for the image specifies the "size of one pixel in x-direction" and "size of one pixel in y-direction". So I would check the resolution of the raster-file to compare the size of image in your units compared to the size of one pixel in the world-file.
    With other words: if you defined a worldfile for a raster-file having 5000x5000 pixel and you then scale the image to 10000x10000 pixel you will get it inserted in double size as long as you don't have recalculated the world-file according to the "half pixel size x and y".
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    antoniovinci
    03-25-2012 04:29 AM in reply to: Joe-Bouza
    Well, given that every image must have its own world file, did you generate it with Raster Design, or what?
    Try this way, and let us know, sir.
