• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Copy,Paste,Erase problem,...
    172 Views, 2 Replies
    09-10-2012 10:56 PM
    When i need erase or copy and paste 10.000 objects it take me more than 1 min,...
    I tried to diferent version of CADmap3d (Autocad Map 3d 2013,2012,2011,2010), but cant help me,...
    CPU: intel core i7 3.4 GHz
    RAM: 8GB
    VGA: Nvidia 1 GB
    windows 7 Ultimate x64
    pleas help me
    :smileysad:
    Please use plain text.
    *Expert Elite*
    Re: Copy,Paste,Erase problem,...
    09-11-2012 05:08 AM in reply to: SepantaMehr
    What object-types are these objects? Simple AutoCAD-geometry like lines, or more complex objects like polylines/blocks or very complex objects like XRef's or proxy-objects .... or are these objects from any referneced GIS-dataset like SHP, SDF, ...
    How big is this drawing?
    Have you tried to first cleanup your drawing using _PURGE?
    Have you verified the number of defined scales in your drawing (command _SCALELISTEDIT)
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Distinguished Contributor
    09-11-2012 01:46 PM in reply to: SepantaMehr
    Unfortunately this is a known issue with 64 bit Acad, and has been a problem for several releases now.  For some reason 64 bit Acad cannot erase large datasets.  It works fine in 32 bit Acad.  I can imagine the incredulous look on your face right now....  Hard to believe this has not been fixed after several releases, erase is such a basic function.
