AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Coordinate transforma tion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How could I transform the following :
PROJCS["albers_dep",GEOGCS["GCS_North_American_198
I will greatly appreciate any help. Thanks!!!!
Re: Coordinate transforma tion
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need to transform ALL your shape, not only that .PRJ file.
There are some ways to convert it, the easiest one is:
1] set UTM83 Zone 18 Feet as main CRS with _ADESETCRDSYS
2] run _MAPIMPORT and load the shape, choosing the Albers' one as CRS going in.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks! I will try that.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Unfortunately, it did not work. Any other suggestion?
Please, I woud really, really be greatful for any help given.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It doesn't work, 'cause you surely have not chosen the Albers' CRS as going in: please attach your MAPIMPORT screenshot, I'll prove it to you.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
open a new dwg and set the coord system to UTM83-18F. You may desire to add some dwg layers that you use regulary to the dwg and save that dwg as a template file. That template can be opened anytime you want to do a map with that coord system.
Use data connect and connect to your .shp file. You will see two heading schema and coordinate system. The cs will either have your albers listed or <unknown> if it is <unknown>, click edit coord systems and set it to the alber cs. and then click add to map. The .shp will be tranformed onto the UTM83-18f.
In Display manager, right click the layer name and do two things, first save layer to a .layer file so anytime you need that layer back in a map you can drag and drop the .lyr file from windows explorer; and second export layer data to SDF which will save the layer in the SDF format. That can alo\so be dragged and dropped into a map or data connected if your need to query the layer data.
You also have the option on the task pane, map explorer tab, tools>bulk copy and create a new shape in the UTM83-18F cs.
Dave
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Still struggling. Of the Albers projection, I only have available: 48 States; NAD27 Albers Equal Area, 1:2,000,000 DLG Files, Meter. I need: 48 States; NAD83 Albers Equal Area, 1:2,000,000 DLG Files, Meter. How do I get or find the latter? Please, HELP!
Thanks a million,
Les
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The closest I see is US48-epng.
try this. I think it gives you what you want but don't garantee it
mapscslibrary
find US48-epng
hi lite and then click the duplicate button
US48-epng_1 is created
hi lite it and click edit
Rename it if you want
change feet to Meters
click view and see if has the parameters you want.
close and then mapcsassign and use it
If it is what youy need you're good to go. Other wise try Corpscon software from the Army Corps of Engineers, that may help. Tommorrow others will be back at work and may provide another solution.
Dave
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have tried it already. It did not work. Thanks, Dave, for trying to help. I really appreciate your effort.
