• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    tom
    Member
    Coordinate system error
    271 Views, 1 Replies
    08-02-2012 08:12 AM
    I get an error message when I load a map with Map 2009 (XP) that was last saved by 2012 (Win7 x64).  The error message is this:
    Warning: Drawing {drawing name} was created with a version of coordinate system {coordinate system name} that is different from the version installed on your system.  Coordinate conversion operations may generate incorrect results.
    I tried opening and saving it with 2009 but the error persists.  What causes this error and what can be done about it?
    Tom
    Please use plain text.
    Re: Coordinate system error
    08-05-2012 01:14 PM in reply to: tom
    That with Map3D2012 there are a lot more coord-systems available then in 2009. And when you now open the drawing with an older Map3D version you either have not defined this coord-system or with other definition-details.
    If you can verify that your 2009-version has a projection-system defined equal to that of 2012 then you should be able to assign it using the command _ADESETCRDSYS.
    If you have not the same coord-system in your 2009-version you will be unable to mix data of different systems with your Map3D and this drawing.
    - alfred -
    Alfred NESWADBA
