AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Coordinate space Map 3D 2008
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am fairly new to AutoCAD and I am running into a problem. I have a drawing wherein the drawing has no coordinate system defined (or so it seems). I have assigned the correct C.S. but when I export/import a SHP file I find that the drawing is in the wrong splace. I have attached a screen shot to show the problem I am having. Can anyone tell me how I can move the entire drawing to the correct spot? Any help would be greatly appreciated.
Andy
Re: Coordinate space Map 3D 2008
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Command: _ALIGN
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
check your units - your lower left corner is indicating feet & inches - I recall seeing a post lately that Map prefers using feet/meters, but not sure if it applies here. check units & insunits for insertion units.
Best of Luck!
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for all the info. The company that created the drawing altered the coordinates (decimal to architectural) and somehow moved the position of the drawing. I was able to reassign the coordinates to the correct one and then rubber sheet the layers to my reference shapefile.
