• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Accepted Solution
    Coordinate space Map 3D 2008
    151 Views, 3 Replies
    06-05-2012 06:14 AM
    I am fairly new to AutoCAD and I am running into a problem. I have a drawing wherein the drawing has no coordinate system defined (or so it seems). I have assigned the correct C.S. but when I export/import a SHP file I find that the drawing is in the wrong splace. I have attached a screen shot to show the problem I am having. Can anyone tell me how I can move the entire drawing to the correct spot? Any help would be greatly appreciated.
    Andy
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Coordinate space Map 3D 2008
    06-05-2012 08:38 AM in reply to: andyb475
    Command: _ALIGN
    Distinguished Mentor
    thepworth
    06-05-2012 10:28 AM in reply to: andyb475
    check your units - your lower left corner is indicating feet & inches - I recall seeing a post lately that Map prefers using feet/meters, but not sure if it applies here.  check units & insunits for insertion units.
    Best of Luck!
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    New Member
    06-05-2012 11:42 AM in reply to: andyb475
    Thanks for all the info. The company that created the drawing altered the coordinates (decimal to architectural) and somehow moved the position of the drawing. I was able to reassign the coordinates to the correct one and then rubber sheet the layers to my reference shapefile.
