• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Denzuki1
    Coordinate System Warning
    285 Views, 3 Replies
    07-27-2012 10:12 AM
    I created a drawing and applied a coordinate system. I saved the drawing and exited autoCAD. Ten minutes later, I started AutoCAD Civil 3D and re-opended the file I created and I get the error I've attached. I believe that one of the coordinate system files is either corrupt or has some sort of lock on it. I have already run a repair on the software. Has someone seen this before?
    Please use plain text.
    antoniovinci
    Re: Coordinate System Warning
    07-27-2012 10:45 AM in reply to: Denzuki1
    You posted in the wrong place, sir: this is a Map forum, not Civil one...
    Valued Contributor
    Denzuki1
    07-27-2012 10:53 AM in reply to: antoniovinci
    My understanding is that Map 3D has these abilities, and I was using the planning and analysis workspace from Civil 3D (which is the Map 3D component). Is this not the case?
    07-27-2012 08:10 PM in reply to: Denzuki1
    Go here: http://docs.autodesk.com/MAP/2013/ENU/files/readme-map.htm#_Coordinate_Systems
    And do what it says. I was having a problem where maps that were brought in with data connect were out in space but if I used mapimport they were correct. I went into the coord systems directory off of read only and when I got back in Civil3d, I got a couple of errors, and then the drawing was fixed. Not sure if that fixed it, or just getting out and back in fixed it, but in Windows 7 that directory has to be unlocked. I unlocked "Geospatial Coordinate Systems" and "Geospatial Coordinate Systems 2013".
    Tim
