• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Connect to Shapefile, Measure Discrepancy
    212 Views, 4 Replies
    02-08-2013 09:44 AM
    I used connect to data to connect to a shapefile of parcels in NAD83 TX-SF. When I measure a specific parcel with MAPDIST or MEASUREGEOM i get 140 feet but when I check the distance in ArcGIS I get 156'. The 156' is correct. It's not just that shapefile, the conversion is consistent with other imported data. The ratio is about 1.114
    Am I missing anything obvious, I'm new to AutoCAD MAP most of my experience is with ArcGIS?
    Please use plain text.
    antoniovinci
    Re: Connect to Shapefile, Measure Discrepancy
    02-08-2013 11:48 AM in reply to: samuel.tooley
    Try to _MAPIMPORT that shape, instead of _MAPCONNECTing it, and check again those distances: any changes..?
    Member
    02-08-2013 11:56 AM in reply to: antoniovinci
    No change, I get the same result.
    antoniovinci
    02-08-2013 12:07 PM in reply to: samuel.tooley
    Would you please zip and attach here the SHP+PRJ files (only, without DBF+SHX), I'm gonna take a look at 'em, sir.
    Member
    02-08-2013 12:59 PM in reply to: antoniovinci
    I found out I was wrong, AutoCAD has the correct measurements, the problem is on the ArcGIS end. Thank you anyways.
