• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Command line, menu browser and key commands not working!
    249 Views, 4 Replies
    06-19-2012 07:58 AM
    Gd morning all,
    I would really appreciate if someone could help me...
    AutoCAD Map 2010 has just been installed in my PC and since i first runned AC the command line, menu browser and key commands don´t work. This way I can´t do anything....................... The IT team from the company that I work for doesn´t understand anything about AC. I don´t know what to do!!
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: Command line, menu browser and key commands not working!
    06-19-2012 09:15 AM in reply to: c.grabher
    do you have dynamic input and no command line???  can you post a screenshot - is the command line hidden (ctrl-9), or is it more nefarious - i.e. strange things can happen if it was installed while the virus protection was enabled and happened to trap some of the .DLL's used by the software - you might just have to reinstall given what you posted :smileysad:
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Member
    06-19-2012 10:20 AM in reply to: thepworth
    The command line is not hidden, I can see it, but when i type it doesn´t appear anything. I can also see the menu browser but when I click in it, it doesn´t happen anything. The same thing happens with the key commands (F1, Ctrl Open...). I have attached a view of the interface, I haven´t made any changes since I first runned the AC.
    Thanks for the attetion,
    thepworth
    06-19-2012 10:24 AM in reply to: c.grabher
    looks like a corrupted CUI, but beyond my experience.  what happens if you log into the computer as a different user - it would create a new profile and you can see if your configuration is corrupted or if it's the installation.
    C3D 2011
    Member
    06-19-2012 10:28 AM in reply to: thepworth
    Thanks a lot, I will try it!!!!
