AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Bring csv file (with additional attributes ) into Map
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I found this post which describes exactly what I want to do to get data into Map http://map3d.wordpress.com/2008/01/02/bring-a-csv-
Isn't there any easier way to get this data into Map??
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Bring csv file (with additional attributes ) into Map
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
search this forum for 64 bit odbc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hola creo que este link te puede ayudar http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Neily,
Murph's post was for the 2008 version - more functionality (i.e. the survey tab under mapwspace) has been added, but you can still follow through & use ODBC to connect to Excel. If using ODBC, you must use a named range in Excel and have the current 64bit excel driver.
If you're really stuck, send me a PM and I'll see what I can do to help walk you through it.
Todd Hepworth, P.E.
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Gracias por esto voy a echarle un vistazo (from Google translate....)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thepworth wrote:Neily,
Todd Hepworth, P.E.
Thanks Todd, I only have 32 bit Office so will need to look at the link in the post from jimyquick....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I also only have 32 bit office.
What I had to do was to uninstall office, install the 64-bit Access driver, reinstall 32-bit office over the 64-bit driver - you can't update the driver with 32-bit office on the machine.
Then use a named range in excel - this is critical.
Worked for me only after upgrading to 2012 - wouldn't work with C3D 2011 for ODBC to excel.
HTH!
C3D 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
neilyj wrote:I found this post which describes exactly what I want to do to get data into Map http://map3d.wordpress.com/2008/01/02/bring-a-csv-
file-into-map-3d-with-data/ but I get stuck almost at the first hurdle (see screenshot).
Yes with the newer version (2010 and up) Use the Mapimport and select the ASCII format, You may need to edit the CVS file a bit but that's one way with out ODBC.
Supportting the troops daily.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for this but when I try the ASCII file, there doesn't seem to be an option to change the input fields....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Neilyj, If you have C3D why not just use the Civil3D opint import tools and create the format you need? Once you import the the cvs as points do a export to Geospatial of that point group to SDF format.
Can you attach a few lines of the CVS file?
