AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Bearing and Distance Command in AutoCAD Map 3D 2010
- Highlight
- Email to a Friend
- Report Inappropriate Content
I was just wondering if someone could please help me out with the Bearing and Distance "Button" or icon in Map 3D. I have used this button before in past versions and have had no problems, but it seems that it is not working now. That is... it will let me enter the quadrant and the easting or northing but as soon as I enter the distance the command cancelss and nothing happens....it just stops working and exits out of the command. I have attached a screen shot of what it looks like. Any help would be greatly appreciated.
lmj
Re: Bearing and Distance Command in AutoCAD Map 3D 2010
- Highlight
- Email to a Friend
Murph
http://map3d.wordpress.com/
"ljohnstone" wrote in message news:6370286@discussion.autodesk.com...
appreciated.
lmj
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
command?
Murph
"ljohnstone" wrote in message news:6370443@discussion.autodesk.com...
Sorry, geuss I should have mentioned that. I am using it with the pline
command. I want to draw a pline at a certain bearing and distance from a
know end point.
- Highlight
- Email to a Friend
thanks
- Highlight
- Email to a Friend
Hi LMJ,
I've been experiencing the same issue, the command cancels and nothing is drawn. I tried it in MAP 2009 as well, and got the same result.
Did you ever get it resolved?
BTW, I have the latest service packs installed so that doesn't seem to be the issue. Maybe it's a 64-bit OS issue?
Randy
- Highlight
- Email to a Friend
It works in C3D 2010. Same command. I used the command line so I could show the steps. Text in braces are my comments.
Command: pline
Specify start point: [ select start point ]
Current line-width is 0.00000000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: 'bd [ initiate transparent command]
Quadrants - NE = 1, SE = 2, SW = 3, NW = 4
>>Specify quadrant (1-4): 1
Current direction unit: degree, Input: DD° MM' SS.SS" (spaced)
>>Specify bearing: 22.5619
>>Specify distance: 136.24 [ pline segment is draw as expected.]
You have to follow the steps
1) Activate Command.
2) Select Start Point.
3) Initiate transparent command.
4) input bearing then distance.
I think some of the procedures are counterintuitive and can lead to errors. I've been caught by this using the Angle distance command. I swore to everyone, including someone from Autodesk, that the command didn't work. It turned out that I wasn't following the EXACT method needed to get it to work.
Hope this helps
Allen
- Highlight
- Email to a Friend
I'm having the same weird effect in 2011 - using the "Cogo" button from the Draw Panel of the Task-based Ribbon.
Trying to enter a point location from a survey plat with published state plane coordinates - drawing a line from the known point gives a command line result versus a graphical entity (line) in my drawing. Strange
Command: bd Specify starting point: _nod of
Enter quadrant (1-4) <3>: 3
Enter bearing <73.3819>:
Specify distance <1557.68>:
"@1557.6800000000<196d37'5.160000\",0.0000000000"
Command:
Note: I've turned off all of the settings like Dynamic input, osnaps, etc - no change in result, but thought it might impact what was happening. when I first started the command from the button on the ribbon, I had a dialog box. subsequent tries sent me to the command line entry. I was about to post my own question when I saw this thread....
WIn7 64Bit, 6GB Ram
- Highlight
- Email to a Friend
it's too late in the evening - got back on the dialog box entry and I can see the line it would draw, but it is a phantom that dissapears when I exit the dialog box, also "create point" doesn't seem put a point at my cogo location like you think it would... time to see what the morning brings ![]()
- Highlight
- Email to a Friend
These are "Transparent Commands". They must be issued while in another command. If you want to draw a line you must first start the line command then hit Bearing and Distance. If you want to enter a point you must first start a command that will create the point. In your case it looks like you'd be using Northing and Easting.
Allen
