AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Batch converting large number of dwg files to pdf
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK, that seams to have done it.
So, I opened a file. opened the page setup for the modelspace. I applied the settings I want and specified in the properties dialog that I want it to print the extents (limits was the default and is what gave me the blank pages). Then hit preview, found the results I wanted. Saved out that file as a template. That was the step I was missing, once I did that all worked fine. In the publish dialog I selected import under the Page Setup and imported the dwt I created. This gave me "ANSI C" as a choice as I saved it to that name in the Page setup dialog. At that point I selected ANSI C from the dropdown and all 5 of my test files published an ANSI C PDF for each drawing at each file's extents.
Now I'll move to the larger list and see how it runs.
Thanks again for the help.
One last question (providing all works well on the larger run) is applying the page setup to each line item in the publish dialog the only way. It's not that big a deal but it seams that there could be a way to apply that dwt to all files added to the publish dialog either at once or when they are added.
Paul
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, you can only save the list to publish if you need to do the publishing more than once with the same files.
At least, mark all lines concurrently, then you need just one assign of the pagesetup and that's it.
HTH, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes apparently I wasn't selecting something right as the first few times I tried to affect all of them the change did not propagate. I tried it again yesterday afternoon and all went well with all files set to the same choice. Thanks for all the help as I’ve finished the whole output and the results are exactly what we needed.
