• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Expert Elite*
    Joe-Bouza
    Bad Shp file?
    118 Views, 8 Replies
    03-07-2012 04:02 PM
    I have the county 2 foot contours and the shp file is about 500 MB. When I try FDO or mapimport with a spacial filter I get nothing or junk, and I am in the correct location. If I get the GIS department to clip out an area I need it comes in as expected.
    What could be wrong and can the shp file and can it be fixed? I tried bring in the whole migilla in to try and convert to sdf but the size of the file kills my work station and I cant get there.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: Bad Shp file?
    03-07-2012 10:32 PM in reply to: Joe-Bouza
    Well, to find the guilty in this case, I would open that huge shape in the opensource "Mapwindow Gis 64 bit": what happens then?
    *Expert Elite*
    Murph
    Re: Bad Shp file?
    03-08-2012 04:59 AM in reply to: Joe-Bouza
    If you're using a spacial filter to bring it in either FDO or Map import I would say the coordinate system is not matching up. Is Civil3D reading the project file?
    Murph
    Supportting the troops daily.
    *Expert Elite*
    Joe-Bouza
    Re: Bad Shp file?
    03-08-2012 05:04 AM in reply to: Murph
    What's the project file? And I'm pretty sure the coordinates are the same how do I check? And like I said if GIS depart clips out the intended area it comes in?
    What I usually do is GE in the location in state plane so I know where I am. And the clipped shp is dead on within the spacial area I originally requested
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Murph
    Re: Bad Shp file?
    03-08-2012 05:11 AM in reply to: Joe-Bouza
    Project = PROJECTION or the .prj file, it's early still down here. :smileyhappy:
    Murph
    *Expert Elite*
    Joe-Bouza
    Re: Bad Shp file?
    03-08-2012 07:56 AM in reply to: Murph
    Ok.
    But if the clipped version works wouldn't that indicate the projection file is correct?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    *Expert Elite*
    Murph
    Re: Bad Shp file?
    03-08-2012 09:54 AM in reply to: Joe-Bouza
    What may be happening is the orginal shp is in one CS (XX) the GIS guy can bring it into a GIS project that is in YY CS, the shp is reprojected to match. They then do a "clip" for you and it, the new shp file takes on the YY coordinate system. So now you have the orginal in XX and a clipped in YY. You can look in the .pro file and see what it says. Notepad will open them.
    Murph
    Distinguished Mentor
    thepworth
    Re: Bad Shp file?
    03-08-2012 11:04 AM in reply to: Murph
    Since the .PRJ projection file is just a .txt file of the CS, what happens if you take the .PRJ for the working clip area and simply rename the .PRJ to match the larger dataset - CLIPPED.PRJ -> Origininal.PRJ and then try to bring it in with FDO & a spatial filter?
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    *Expert Elite*
    Joe-Bouza
    Re: Bad Shp file?
    03-08-2012 03:26 PM in reply to: thepworth
    That sounds like it worth a try. I'll let you know
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
