• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    AutoCad Map
    140 Views, 1 Replies
    04-25-2012 10:20 AM
    Trabajo con puntos Lidar, originalmente en formato LAS y necesito editarlos clasificandolos en funcion de la intensidad, alturas...
    La nueva versión 2013 podrá hacer estas funciones?
    Que plugin podria adquirir para realizar la edición de puntos LIDAR
    Gracias
    J.López
    Please use plain text.
    Product Support
    borycep
    Re: AutoCad Map
    04-27-2012 02:20 PM in reply to: etyaf
    Sr. Lopez,
    I understand that you wish to stylize a point cloud based on intensity.
    This is possible by following the steps outlined in this video:
    http://docs.autodesk.com/MAP/2013/ENU/training_videos/Working%20with%20Point%20Clouds.html
    Although the video was produced in the 2012 product, the steps are exactly the same for the 2013 product.
    You do not need a plugin to accomplish the above, you already have everything you need (.LAS file and AutoCAD Map 3D)
    Best wishes to you!
    Phil
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
