• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    AutoCad Map 3D 2012 and MapGuide - Open source - publishing
    412 Views, 6 Replies
    08-29-2012 11:49 PM
    Is there any chance to publish data / maps from AutoCad Map 3D 2012 to MapGuide - Open source map server ? Is there any support from Autodesk for this ?
    Thank you !
    Please use plain text.
    Valued Contributor
    ro_fr
    Re: AutoCad Map 3D 2012 and MapGuide - Open source - publishing
    08-30-2012 10:31 PM in reply to: greg_sk
    that should work if MapGuide OS is compatible to the Map version you are using. I'm not sure if the matrix here will tell you which version of Map works with MG OS:
    http://fdo.osgeo.org/content/products-using-fdo
    But I suppose the FDO version used by both packages should be the same.
    Rob
    Member
    08-30-2012 11:22 PM in reply to: greg_sk
    I'll try to install apropriate MapGuide. I can't find FDO provider for AutoCad Map 3D 2012 but we still have version 2012 so I'll start with that.
    Thank you !
    Valued Contributor
    ro_fr
    08-30-2012 11:27 PM in reply to: greg_sk
    You are right - I didn't notice that. Just post your question to the MGOS discussion list as well if no one else can help here.
    http://osgeo-org.1560.n6.nabble.com/MapGuide-Open-Source-f4182606.html
    Member
    08-31-2012 01:15 AM in reply to: ro_fr
    I know for this forum. I have already registred there because I have problems with displaying raster data in MapGuide OS.  Thanks for advice.
    08-31-2012 01:18 AM in reply to: greg_sk
    If you're talking about the MAPPUBLISHTOMAPGUIDE command, it probably does a major.minor site version check against the MapGuide server you're publishing to as a way to check if it will recognise the requests that the publisher will send to it.
    In which case, the current stable version of MGOS (2.2) probably won't work from Map 2012 as it will probably be expecting AIMS 2012 (2.3) at a minimum. It may work with the 2.4 RC1 release (don't have Map 2012, can't confirm)
    - Jackie
    Member
    09-12-2012 10:44 AM in reply to: jackie.ng
    Hi greg_sk!
    You can publish to MapGuide Open Source 2.2 with Map 2011, but not with 2012. Just tried it, seems to work just fine. In my experience if MapGuide Studio can connect to a given version of Open Source Mapguide, then Map can publish data to it.
    Cheers, G
