• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    AutoCAD saving is not responding 64bit
    165 Views, 0 Replies
    01-01-2013 10:13 PM
    Hi all
    Computer-1
    AutoCAD Map 3D 2012 32bit
    4GB Ram
    Computer-2
    AutoCAD Map 3D 2012 64bit
    8GB Ram
    Everytime I open large drawings
    contains 20000 BlockReferences with each block
    included 40 attributes. It l take a long time to save.
    AutoCAD is not responding on two computers.
    First thing I would check is Options > Open and Save tab.
    Look in the upper left under Save Version as.
    Make sure that Maintain Visual Fidelity is turned off.
    When that is turned on and you have annotative objects, it will take a long time to save.
    I solved problem only on first computer 32-bit.
    Computer 2 is still not responding.
    I  hope someone could help me out.
    Thank you in advance.
    Please use plain text.
