• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    AutoCAD Map 3D, Windows 2008 and Terminal Services
    296 Views, 2 Replies
    02-03-2010 06:09 AM
    Has anyone ran AutoCAD Map 3D through Terminal Services on Windows 2008 R2 X64 ?
    Please use plain text.
    New Member
    Re: AutoCAD Map 3D, Windows 2008 and Terminal Services
    03-12-2012 11:07 AM in reply to: tebo-citrix
    I'm looking to do the same thing with AutoCAD Map 3D 2012 and Windows 2008 Standard 32 bit.  Do you know if that is doable?
    Product Support
    03-13-2012 07:17 AM in reply to: mcoulsto
    Citrix is supported as a way to run multiple sessions of Map and some other AutoCAD verticals from a single system.  WIth other options you'll run into limitations very quickly (and violoate the licensing agreement).  Even for Citrix, you'll need a Citrix specific network license.  www.citrixandautodesk.com has some useful pointers.
    Nate Moore, GISP
    Geospatial Premium Support Specialist
    Global Services
    Autodesk, Sarl
