• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    AutoCAD Map 3D 2013 constant FATAL ERRORS
    398 Views, 4 Replies
    10-19-2012 12:41 PM
    I just downloaded a free trial & was able to import one shape file... The error occured when I tried importing a second shape file. I was able to recover the drawing once starting the program back up. As soon as it opens, the fatal error occurs again. I was unable to get anywhere after that. The imported shape files are only 1MB & 3MB's "large". I was under the impression this is a full trial version. Are there any size restrictions with it? What can I do to fix this issue?
    Any help would be appreciated.
    Robyn
    Please use plain text.
    Re: AutoCAD Map 3D 2013 constant FATAL ERRORS
    10-19-2012 03:20 PM in reply to: rckohler
    The only restriction is the 30-day limitation, nothing else is different in functionality from the activated product.
    Some questions to isolate the problem (hopefully):
    • Where do you have the SHP-data from?
    • Have you tried to use _DATACONNECT to not import, but reference the SHP-data into your current drawing?
    • What coordinate-system do you use / which coordinate-system comes the SHP from?
    • Do you have any othter product that shows these SHP without errors?
    - alfred -
    Alfred NESWADBA
    10-22-2012 05:51 AM in reply to: rckohler
    I added a few shp files into my drawing using Data Connect. So far, no issues.
    Thank you!
    10-22-2012 05:55 AM in reply to: rckohler
    does that mean that you can work now as you need?
    ...or is that just the confirmation for "the shape-files are ok"? (then I miss the answers to the other questions)
    - alfred -
    Alfred NESWADBA
    10-22-2012 06:38 AM in reply to: alfred.neswadba
    Yes, I can work in my file as I need. The shp data is from Michigan GeoRef (MGRm). I am currently using M183-OB coordinate system (meters); which is what the shp files use.
    Thanks again for the help!
