• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    AutoCAD Map 3D 2012 crashing when plotting
    234 Views, 5 Replies
    04-20-2012 08:01 AM
    This is a problem that has started up in the last week.
    When one of our users try to Plot, Publish or use Page Set Up, AutoCAD crashes to desktop.
    No Error Codes come up.
    This is happening with both new drawings or legacy drawings.
    Please use plain text.
    *Expert Elite*
    Re: AutoCAD Map 3D 2012 crashing when plotting
    04-20-2012 10:54 PM in reply to: staped
    if I understand your situation correctly, you start AutoCAD, create a new drawing (based on an Autodesk original template), goto layout and start plot:
    • you don't get the plot-dialog and it crashes   ....or
    • you get a plot-dialog, you define your printer (which one) and then press "PLOT" and it crashes     ....or
    • you get a plot-dialog, you set up to print to DWF and then you press "PLOT" and it crashes
    If you get the plot-dialog, does PREVIEW work?
    Let us know the ansers to the above questions. :smileywink:
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    antoniovinci
    04-21-2012 01:29 AM in reply to: staped
    Member
    04-23-2012 06:52 AM in reply to: alfred.neswadba
    It crashes prior to getting to the dialog box.
    Plot preview crashes it.
    Page setup crashes it with a new drawing, no dialog box.
    Member
    04-23-2012 06:53 AM in reply to: antoniovinci
    We have the Service pack installed.
    *Expert Elite*
    antoniovinci
    04-23-2012 07:37 AM in reply to: staped
    Restart that pc, log in as administrator WITHOUT netwoking, and try to plot from Autocad: any changes?
