• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    wesbird
    AutoCAD Map 2012 stop working
    326 Views, 3 Replies
    09-13-2012 01:09 PM
      My AutoCAD Map 2012 suddenly stop working. It may related to Map 2013 I installed a couple days ago.
      everytime I try to run 2012, I got this and crash
    C:\Program Files\Autodesk\AutoCAD Map 3D 2012\acmapdmtask.arx cannot find a procedure that it needs.
    AcRxDynamicLinker failed to load 'acmapdmtask.arx'
      I uninstall 2012, clean, re-install 2012, I got this in the middle
    Failed to find node: //configuration/Connect/VDrive in XML file: C:\Program Files (x86)\Autodesk\Content Service\Connect.Service.ContentService.exe.config, system error: -2147020584
      It still install 2012 on my machine. but still the same error message and crash.
      What could be the problem? Should I uninstall 2013 and try again?
    Thank you so much
    Wes
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: AutoCAD Map 2012 stop working
    09-13-2012 10:50 PM in reply to: wesbird
    Don't dare to do that, sir: you'd better restore a system state prior to the 2013 install, i.e. to a "bold" previous date.
    WIN-R => RSTRUI => OK
    wesbird
    09-14-2012 08:31 AM in reply to: antoniovinci
    Thank you, antoniovinci
    Could you please provide more detail instruction?
    Wes
    *Expert Elite*
    antoniovinci
    09-14-2012 11:44 AM in reply to: wesbird
    1] press simultaneously the keys WIN (between CTRL and ALT) and R (between E and T)
    2] in the small opened window, type in RSTRUI and click OK
    3] choose a date previous than the 2013 installation, and go on until Windows restarts.
    This method kills every installed program after that date, preserving the user data.
