AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Advice - AutoCAD MAP3D vs MapInfo and ArcGIS
- Highlight
- Email to a Friend
Hi
Ive been trying to find feature comparison data between AutoCAD MAP3D and GIS software such as Mapinfo and ARC GIS but it seems hard to find. Can any AutoCAD MAP3D users here give me some advice on how the GIS capabilities of AutoCAD MAP3D differ from those of these other GIS products.... is AutoCAD MAP3D a fullly functional GIS package?
Re: Advice
- Highlight
- Email to a Friend
Ok, I start ![]()
first: I don't know MapInfo, so I can only compare ArcGIS and Map3D (more used ot Map3D, of course).
second: whatever forum you start such a thread will result in "the software I use is the best", in that case here all use Map3D, so guess what percentage of users will mark Map3D as best ![]()
So you should also start such a thread in the ArcGIS and MapInfo discussion forums.
And now:
Yes, it is.
The global points I see worth to be mentioned:
+ AutoCAD Map3D ==> editing geometry
- as Map3D is based in AutoCAD you have a full set of tools for creation and modification of geometry (otrack, osnap, grip-functionality and a lot more)
+ AutoCAD Map3D ==> plot
- the setup of a layout, including titleblock, multiple viewports, .... all is relativ easy to create compared to ArcGIS
- using a lot of different plotters and plot formats (especially oversizes) is no problem for AutoCAD-based products
+ AutoCAD Map3D ==> geometry cleaning / creation of topologies
- one of the functions I really love. Check existing geometry for defects like overshoot, undershoot, crossings, ... With a given tolerance Map3D is able to handle/repair that defects.
- so also creation and manipulation of really topological data is a thing Map3D is able to do that. E.g. don't think that modifying a SHP in ArcGIS is topological proofed, you might get then overlaps or holes in your working area without any warning.
+ ArcGIS ==> analyses
- ArcGIS has it's strength in analyses, Map3D get closer and closer to the abilites of ArcGIS, but Map3D has not all types of analyses yet that ArcGIS offers
+ ArcGIS ==> data amount
- currently ArcGIS can handle much more data on high performance, especially for thematic maps. It's not a problem for 1000 or polygons, but if you have > 100000 polygons and they have to be filled in different colors based on any attributive field makes Map3D slow on display while ArcGIS plays around.
And now waiting for others, that's just my 2c ![]()
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Re: Advice
- Highlight
- Email to a Friend
Thank you Alfred
"ArcGIS ==> analyses
- ArcGIS has it's strength in analyses, Map3D get closer and closer to the abilites of ArcGIS, but Map3D has not all types of analyses yet that ArcGIS offers"
Would you be able to elaborate on this..... especially in terms of what Map3D cannot do?
Re: Advice
- Highlight
- Email to a Friend
e.g. statistics like show on each label of a polygon a pie-chart of a percentage value of a sum of any value in the attributes
or ... in some cases it's hard to get labels as text-objects in case of high number of polygons (Map3D gets then slow on screen) and sometimes the intelligence of Map3D is to high to hold a text within it's polygon (well there are workarounds for that).
But to be honest: analyses like "create a thematic map" can be done with every of these packages, the difference there is in very very small details.
- alfred -
Alfred NESWADBA
Re: Advice
- Highlight
- Email to a Friend
DO you know how they compare in terms of spatial analysis?
Re: Advice
- Highlight
- Email to a Friend
I see no difference in doing analyses based on geography location/properties or on based on attributive properties.
Both doing that.
Maybe to give you one idea: besides the internal topological functionality in Map3D you have also the functionality from OSGEO built in (>>>click<<<).
- alfred -
Alfred NESWADBA
Re: Advice
- Highlight
- Email to a Friend
Thanks, would greatly approciate coments from other members to ![]()
Re: Advice
- Highlight
- Email to a Friend
arunrnf wrote:Thanks, would greatly approciate coments from other members to
I concur with everything Alfred stated, just add that labeling features with attributes may be easier in ESRI.
The other main differeance AutoCAD Map3D has 3d build in, the last version of ArcGIS I used it was an add module that you paid extra for.
Supportting the troops daily.
Re: Advice
- Highlight
- Email to a Friend
Alfred mentioned a plotting advantage for Map3D, and I have to agree that the multiple layouts is a huge advantage, but if you ever need to do a mapbook, (as some of us still do once in awhile), then the data driven pages in ArcGIS beats Map3D hands down.
Re: Advice
- Highlight
- Email to a Friend
I am primarily an ArcGIS user but actually started with CAD and I while I prefer ArcGIS for Making actual maps I do greatly miss the geometry editing ease of AutoCAD. Now I have Map 3D and am just getting into learning how to use it. The ribbon based layout is different from what I learned on (14 and 2000) but that will be a minor issue overall. Me I plan to use a blend of the two to my best advantage.
Paul
