• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Adjustable Bar Scale
    259 Views, 5 Replies
    05-28-2009 08:48 AM
    I work with Autodesk Map 3D and I was wondering if the latter provides a bar scale that will adjust automatically to the size of the plotting paper.
    Thanks a million!
    Please use plain text.
    Valued Contributor
    Re: Adjustable Bar Scale
    05-28-2009 10:34 AM in reply to: Victoria12
    Not currently.
    I have had to build one useing the Field comand linked to the viewport. The scale itself remains static, but the numbers change.
    This is also linked to the scale at the bottom if you are useing A-cad 2008,09,or 10.
    Active Contributor
    05-28-2009 10:44 AM in reply to: Victoria12
    Thank you so much for replying.
    Active Contributor
    05-28-2009 12:07 PM in reply to: Victoria12
    I am trying to create an adjustable Bar Scale using the field command, as advised by Soocom1 above.
    I chose 1"= #' from the field menu. It gave me the following: 1" = .2154' .
    In the field expression box, I got the following:
    %<\AcVar.16.2 PlotScale \f "1\" = %lu2%zs12%ct9[0.0833333333333333]'">%
    The Edit Scale List is set to 1"=1" where 1' of paper is equal to 0.08333333 drawing feet.
    Where does the number 0.2154 come from?
    Thanks a million!
    Active Contributor
    05-30-2009 09:43 AM in reply to: Victoria12
    Help..anybody?
    Thanks a million!
    Active Contributor
    08-09-2012 08:35 AM in reply to: Victoria12
    2013 has a scale bar tool.
