• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    agirard2003
    Addind a raster image locks up Autocad Map 2012
    252 Views, 2 Replies
    05-16-2012 06:42 AM
    I've rebooted, re-installed and nothing changes the fact that when i try and insert a raster image the program locks right up.
    I can go back 2009 version and have no problems inserting the same raster.
    Anyone have any solutions or experience the same problem?
    the raster is a Mr.Sid format file
    Please use plain text.
    Member
    agirard2003
    Re: Addind a raster image locks up Autocad Map 2012
    05-24-2012 07:29 AM in reply to: agirard2003
    nothing really?
    AUTODESK are you there?
    05-24-2012 11:45 AM in reply to: agirard2003
    I'm not Autodesk, but I miss some info of what you have tried yet :smileywink:
    • Have you tried to convert the file to e.g. a TIFF-format, does it then also hang up?
    • What command did you use to reference the image?
    • Have you setup a coordinate-system for your drawing? Have you  tried to insert the image when another coord-sys is assigned to your drawing
    • Have you tried to insert the image into another drawing?
    • Have you installed the latest service-packs for Map3D?
    • Have you tried to start Map3D with another profile (or with another Windows user-account) to mmake sure it's not specific to your current AutoCAD-profile?
    • Have you tried to toogle hardware-acceleration?
    ...or what did you try up to now?
    - alfred -
    Alfred NESWADBA
