• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Mentor
    thepworth
    Re: Add new shp to existing shp
    01-20-2012 09:24 PM in reply to: alfred.neswadba
    did you try "import polygons as closed polylines"  - a checkbox in the mapimport command - to see if that makes a difference since you won't have the mpolygons?
    Just a thought from looking at the image and seeing all of the polygons as filled shapes.  closed polylines usually wouldn't be filled like that.
    TdH
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Please use plain text.
    Active Contributor
    KrakowiAneczka
    04-13-2012 04:38 AM in reply to: KrakowiAneczka
    Hello again Everybody!
    I wasn't here for a while - busy, busy, buy I was! (still am!)
    could I please refresh the topic?
    I have received 3 shape files with parcels information. In those files there are about 1000 parcels, each has got ID.
    I also created additional shape with new parcels.
    I also have access data base with additional information for those parcels.
    I'm using data base to theme the plans I'm creating. The data base is updated regularly.
    In order to theme plans properly I need to create new shape files with information from data base "build in them" therefore I need to create joints, export to new shapes and all of that would be easier if I only have one master shape file.
    Exporting to CAD geometry is not an option bacause it looses the id.
    Anyone has an idea?
    I'm using Map 2012 but may use 2013 if it has got that functionality.
    Thanks!
    Ania
    *Expert Elite*
    antoniovinci
    04-13-2012 05:38 AM in reply to: KrakowiAneczka
    Witaj !
    What about exporting all to a complete .SDF file?
    New Member
    KrakowiAneczka
    04-13-2012 05:44 AM in reply to: antoniovinci
    Oh, yes, that's a good idea :smileyhappy: but how exactly to do that?
