• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    indianadarren
    Access file not attaching
    471 Views, 7 Replies
    02-27-2012 09:02 PM
    I am trying to ATTACH this Access file. I'm in the Task Pane, map Explorer tab, selecting the Data Source icon. I have used the right click - attach method, as well as the two other methods of Attaching DATA sources (i.e. drag & drop)...nothing is working. Any ideas? Is the file bad?
    Attached for your consideration
    haha, just got this error message when I tried attaching it to this post: "The file does not have a valid extension for an attachment.doc,pdf,dwf,dwg,dxf,dst,gz,gzip,zip,bm,bmp,gif,jfif,jpe,jpeg,jpg,psd,tif,tiff,png,htm,html,xml,xls,lsp,svf,3ds,vcf,png,text,txt,log,env,dcl,rvt,rfa,ipt,iam,ipn,dwfx,idw,csv,nwf,nwc,nwd,sdf,cfz,vtfx,vtf are the valid extensions."
    If you include your email address I will send it to you for your consideration.
    thanks in advance!
    Please use plain text.
    *Expert Elite*
    Re: Access file not attaching
    02-28-2012 02:45 AM in reply to: indianadarren
    You can connect to MS-Access with two ways
    • using command _DBCONNECT
    • using command _MAPCONNECT and try it via ODBC
    ....and please say you have a 32bit OS, otherwise you have to work with workarounds (as there a no drivers for MDB-files for 64bit except you install >>>this<<< and that may be problematic with some kind of office-installations).
    To verify what's now the better method depends on what you like to do with the MDB-data.
    You can't "attach" is as reference as the MS-Access database has no graphical objects to be shown on the modelspace.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    indianadarren
    02-29-2012 03:20 PM in reply to: indianadarren
    No, not working. I have a map file without data. I have an Access file with data. According to the following url, I should be able to link them and then generate a link template.
    http://docs.autodesk.com/MAP/2010/ENU/AutoCAD%20Map%203D%202010%20User%20Documentation/HTML%20Help/i...
    also, here:
    When I follow the Autodesk "How to Instructions" the results are attached as a jpg. Epic failure, but only @ work - this works fine on my home computer (piece of crap laptop). Are the problems linking Access data to map files?
    indianadarren
    02-29-2012 03:28 PM in reply to: alfred.neswadba
    RDBMS:[Microsoft][ODBC Driver Manager] The specified DSN contains an architecture mismatch between the Driver and the Application.
    This is the specific error
    hope it helps
    *Expert Elite*
    03-02-2012 02:05 AM in reply to: indianadarren
    and the main question once more: you are working on 32bit or 64bit?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    ajilal.vijayan
    04-05-2012 06:44 AM in reply to: indianadarren
    Hai,
    I am working on 64bit , windows 7 and using Civil 3d 2012.
    I am also getting the same message while I trying to connect to access or Excel.
    Pleae have a look at the images attached.
    Active Contributor
    04-05-2012 08:03 AM in reply to: indianadarren
    If you are running Windows 7 (64-bit) with AutoCAD 64-bit you can't connect to 32-bit Microsoft Access/Excel without significant workarounds.  Search this forum for the workarounds.  The easiest workaround is to install a 64-bit version of MS Office.  Otherwise you have to uninsall 32-bit MS Office, download a MS Access driver 64-bit from Microsoft and then reinstall the 32-bit MS Office.  This information is based on my recollection from reading similar posts on this subject.
    Valued Contributor
    ajilal.vijayan
    04-08-2012 11:21 AM in reply to: indianadarren
    Hai,
    Thanks for your reply and forgive me for my late reply.
    Yeah now I have to deal with our IT team and let see what happens!!
    At the same time I have done some workaround and I found this article saying that you can use The 32-bit version of the ODBC Administrator tool on 64-bit platform.
    But again I need the IT team to solve it.
