• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Accepted Solution
    2012 Map 3D Install Missing dll
    966 Views, 2 Replies
    08-09-2011 04:14 PM
    I Downloaded, Installed and Reinstalled Map 3D 2012 but it still tells me it can't find dll. See below. I am clueless as to what to do next. Help. TYIA
    dll or other file that it needs.
    c:\program files\autodesk\autocad map 3d 2012\acmapdwfapi.arx cannot find a dll
    .Failed.
    AcMapWorkspace.arx Load Failed
    AcMapDwfApi.arx Load FailedRegenerating model.
    c:\program files\autodesk\autocad map 3d 2012\acmaploader.arx cannot find a dll
    c:\program files\autodesk\autocad map 3d 2012\bin\tbexporter.arx cannot find a
    AutoCAD menu utilities loaded.
    Command: _RIBBON
    Command: COMMANDLINE
    AutoCAD Map 3D 2013
    Windows Vista Business
    Service Pack 2
    Intel(R) Core(tm2) Quad 3.0 GHz
    4.0 GB RAM
    Please use plain text.
    Re: 2012 Map 3D Install Missing dll
    08-09-2011 05:18 PM in reply to: grimline
    Figured it out. The Fail happens when I imported my Profile from Map 2010.
    I deleted the Profile and created a new one for Map 2012.
    Everything is fine now.
    TY
    AutoCAD Map 3D 2013
    Service Pack 2
    4.0 GB RAM
    New Member
    ChrisFullmer
    04-26-2012 05:06 PM in reply to: grimline
    To be more specific, for me the folder that needed to be added to the support files was:
    C:\Program Files\Autodesk\AutoCAD Map 3D 2012\bin\FDO
    That is a folder that contains a lot of dll's.  Now I'm not getting any more dll errors.  I'm not positive that is the precise right thing to do, but it seems to work at this point.
