• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    2.5D Buildings
    209 Views, 13 Replies
    04-27-2012 12:51 AM
    I want to create 2.5D Buildings, like at google maps website.
    example
    anyone know how to do it?
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: 2.5D Buildings
    04-27-2012 01:09 AM in reply to: jeffb1910
    Select your lines or 2D poly, then Properties and change the THICKNESS value.
    If you wanna instead get 3D objects, simply issue _EXTRUDE on closed polylines.
    Active Member
    Re: 2.5D Buildings
    04-27-2012 09:13 AM in reply to: antoniovinci
    I press "connect" and then "Add SHP Connection".
    I Chose the 2D shp file, connect it and then add to map.
    I have height value and i want to create 2.5D Buildings from my data, like google maps example
    what is my next step?
    Thanks!
    *Expert Elite*
    Re: 2.5D Buildings
    04-27-2012 09:43 AM in reply to: jeffb1910
    in that case you can't use the FDO technology as you need AutoCAD polylines for extrusion.
    So use command _MAPIMPORT, after you selected type SHP and the filename don't forget in the next dialog to go to the 3rd tab and mark "use closed polylines for polygons" (not the exact wording).
    Then you have polylines and can do what antoniovinci suggested to do.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Member
    Re: 2.5D Buildings
    04-27-2012 11:02 AM in reply to: jeffb1910
    i used the mapimport command and its import points instead polygon
    *Expert Elite*
    Re: 2.5D Buildings
    04-27-2012 11:06 AM in reply to: jeffb1910
    what version of Map3D do you have?
    Are you sure that you selected the correct SHP-file? Because I don't know any option within Map3D that creates points from a polygonal shape!
    - alfred -
    Alfred NESWADBA
    Active Member
    Re: 2.5D Buildings
    04-27-2012 11:10 AM in reply to: alfred.neswadba
    AutoCAD Map 3D 2013
    Active Member
    Re: 2.5D Buildings
    04-27-2012 11:13 AM in reply to: jeffb1910
    it was my mistake! sorry!
    *Expert Elite*
    Re: 2.5D Buildings
    04-27-2012 11:17 AM in reply to: jeffb1910
    Could happen always and to everyone, don't worry!
    - alfred -
    Alfred NESWADBA
    Active Member
    Re: 2.5D Buildings
    04-27-2012 11:21 AM in reply to: alfred.neswadba
    Now i can see the 2d polygon of buildings.
    i have the height value for the polygons.
    How i can convert the polygon to 2.5D like google maps?
    Thanks!
