• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D Wishes
    Active Member
    IMAGE DRAW ORDER
    316 Views, 1 Replies
    06-20-2012 10:14 AM
    Wouldn't it be nice to NOT have to "send to back" 50+ times a day?!?!? When choosing my draworder I expect it to stay to the back. When my map base is set up in my Map 3D task pane to remain the bottom layer, it should indeed be the bottom layer. I'm still having to select the image and "send to back". There's obviously a bug in the program.
    Please use plain text.
    New Member
    Re: IMAGE DRAW ORDER
    06-27-2012 02:10 AM in reply to: MeagenM
    If I compare Map 3D 2012 with 2013, there are problems again with the draworder. Ok to be honest I never liked draworders in AutoCAD, since my first steps with ACAD 2k there where always problems with blocks and hatchs. Why is it important when you created an object and not in which order it should be?
