• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D Wishes
    Valued Contributor
    Data View Find and Replace.
    476 Views, 3 Replies
    10-29-2009 10:47 AM
    While working with a linked database in the data view it's not possible to use the Edit>Replace tool. This is a huge flaw. In every other application for working with a data set there is a way to use the find and replace function. My current work around involves either copy and paste (very time consuming) or opening the Access database to use Microsoft's fancy find and replace. I also use ArcMap quite a bit and working with data in their environment is much preferred and mainly because it's easy to make changes. My wish... while I continue to copy and paste... would be... to some day click on 'replace all'. It's not a big dream. :smileyhappy:
    Please use plain text.
    Valued Contributor
    Re: Data View Find and Replace.
    04-23-2010 09:37 AM in reply to: briancoward
    It's been 176 days since my dream was posted. Oh... I hope... I hope!!
    *Murph
    04-23-2010 09:49 AM in reply to: briancoward
    Hope you're not holding your breath waiting for it.
    With a 64 bit os you can not even data link or data connect to a MS Access
    file.
    Murph
    http://map3d.wordpress.com/
    "briancoward" wrote in message news:6379408@discussion.autodesk.com...
    Valued Contributor
    03-23-2012 10:33 AM in reply to: briancoward
    It's now been 876 days.  Have I missed any improvements to linked data in AutoCAD Map?  I'm using 2011.
