AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
what is BEST to use in making.....
4 REPLIES 4
343 Views, 4 Replies
hi there.
i want to ask if what is BEST to use in making a interactive 3d map of a building and will be paired for Unity?
3d max design or 3d max????
am new on this software so i dont know ..hope someone helps that has background in making building in 3d..
thanks,,
4 REPLIES 4
antoniovinci
CloudZELL91 wrote:
making a 3d map
Well, seems like you googled "3D MAP" and you arrived here, in the official "MAP 3D" forum...
We talk about geographic maps, not "building" maps or plans, sir.
Anyway, unless you are an architect (for which the best answer would be "Revit"), I advise you to check this out.
hence_the_name
why don't you post your question in the 3d max forum? What has AutoCAD Map and this forum to do with your question?
http://forums.autodesk.com/t5/3ds-Max/ct-p/area-c1
Rob
http://raumpatrouille3d.blogspot.ch/
in reply to: antoniovinci
apologies,, guys,,,am new here..dont know where to post
,,,and am not an architect.... we are required to use 3d max and dont know which one..and again sorry.. for posting here...
in reply to: hence_the_name
sorry sir...for posting here am just new here and just confuse on where to post... again apologies...and thanks for the link..
”Boost
