AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
very,very slow FDO label - map is unusable
3 REPLIES 3
kalmy
400 Views, 3 Replies
The map 2014 is very slow in FDO label . Map is unusable if the label is showing, the cursor freeze or move very very slow.
Also the same effects is in 2013  but not in 2010.
I tested on different workstation with different configuration and the behavior is same.
Albert
3 REPLIES 3
braudpat
in reply to: kalmy
Hello
You are speaking about ACAD MAP 201X 32 or 64 bits ?
And with how much memory on your PC ?
How many FDO Labels ?
Are you using MText (Default option for MAP 2012-2014 FDO Labels) or Standard Texts ?
MAP 2010 + SP 2 ?
MAP 2013 + SP 1 ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
kalman_albert
in reply to: braudpat
This function (below)  if exist in Ms SQL the labeling process in map is killed.
If somebody can test I will appreciate. We test more then 7 workstation for 2013/2014 ..
But the issue is not present in 2010/2012.
Nasty function.
Please try this with MS SQL Server.
Create function [dbo].[fct_getCoefPctIntersectie](
--coord dreapta
@LX1 decimal(28,20)
,@LY1 decimal(28,20)
,@LX2 decimal(28,20)
,@LY2 decimal(28,20)
--coord punct
,@PX decimal(28,20)
,@PY decimal(28,20)
)returns decimal(28,20) as
begin
Declare @u  decimal(28,20)
Select @u = ((@PX-@LX1)*(@LX2-@LX1) + (@PY-@LY1)*(@LY2-@LY1)) /
((@LX2-@LX1)*(@LX2-@LX1)+(@LY2-@LY1)*(@LY2-@LY1))
return @u
end
Tasks to reproduce.
Run the SQL function.
Open AutoCAD Map, Data connection , add map any geom table . Generate label . The cursor move very slow.
"Nothing will ever be as it was!"
braudpat
in reply to: kalman_albert
Hello
Sorry no MS -SQL Server !
Have you tried to generate standard Texts Labels ?
Please NOT Multi-Texts Labels (which is the DEFAULT option) !
Bye, Pat
Patrice BRAUD
”Boost
