Araki,
Can you provide me a copy "small sample" of the dwg that you are working
with along with the ArcVeiw shape files of the same and I'll see what can be
done. Also what are you are your plans on using the topology after you
create it? There may be another way of getting the results you need
depending on what it is you want.
Murph
cad4703"AT"bellsouth"DOT"net
wrote in message news:5209989@discussion.autodesk.com...
Hi all,
I am wondering if anyone has experience(or a technique) for making a map
topology with "islands"? I want to build a topology of a Specific Plan that
we are starting to work on and I have a couple of Open Space polygons that
have a pedestrian walkway that "cuts" through.
I have built many topology's but this is a new one to me. I can do it in
ARCVIEW, but Autocad Map has a problem with making the "ped" crossing it's
own polygon.
I read on one of the posts that mpolygons are supposed to handle this,
problem is you can't export to .shp files with mpoly's.
Also, is it better to create a topology with polylines or just lines? I
didn't know that there would be a difference when you choose between the
two.
Thx a lot,
