AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
thematic Object query... please help
2 REPLIES 2
404 Views, 2 Replies
I'm working with Map 5, but I've some problems with the Thematic Object
Query:
I've an Access Database that is connect with the drawing, when I try to
execute a thematic query Map dont paint some zone, but these zone are linked
with my Db...?
How I can to do?
Thank's in advance.
Ale
2 REPLIES 2
msepulveda
Idem problem, same problem in the version Land Development Desktop 3 and MAP5
the "object Thematic Query" of Map5 not execute. the same query in MAP4
is ok in 8 seg.
ideas?
solution?
hugo-huapaya
Hola Miguel aparentemente el problema esta en los parametos de limpieza de objetos (Object CleanUp), deja los valores por defecto y por lo menos esta funcionando
Hugo
”Boost
