AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
.str format data
3 REPLIES 3
nik.mazreen
4643 Views, 3 Replies
.str format data
is there any way to work with string file (.str) from autocad map 3d?any fdo provider support this type of format data?
thx in advanced..
-nik-
3 REPLIES 3
antoniovinci
in reply to: nik.mazreen
Which of the following ones do you refer to..?
http://www.fileinfo.com/extension/str
NateMoore
Not directly, I think.  You might look at Safe to see if they have it listed: http://www.safe.com/fme/format-search/ .  Otherwise, exporting from the source in a more common format will be the best option.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
nik.mazreen
in reply to: NateMoore
thx for the reply..
actually this string file (.str) is created from the software called GEMCOM SURPAC.
i think you are right, i guess the best way to read this format in map 3d is to convert it to common format.
”Boost
