AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
shapefile to 3dpolyline conversion
4 REPLIES 4
ouspensky
488 Views, 4 Replies
I have a shapfile of multipart line features (i.e. polylines)  I draped them on a 3d surface in GRASS GIS and exported a shapefile.  now how do i get that shapefile to display in 3D inside civil 3D through FDO connection?
second part:  how do I import that shapefile as a 3D polyline into Civil3D to generate breaklines?
4 REPLIES 4
in reply to: ouspensky
Did you use _MAPExtractFeatureGeometry command?
antoniovinci
Are you really sure Grass created a 3D shape, sir?
Please share it with us here, if you'are allowed to, thx.
Murph_Map
If it is a true 3d shp file mapimport will create the 3d ploylines when imported, FDO connections are all 2d for shp files.
I'm willing to say by drapping it in GRASS does not convert the 2d to 3d.
Murph
Supporting the troops daily.
braudpat
in reply to: Murph_Map
Hello
Can you do an "standard" MAPIMPORT from your 3D SHP file ?
If YES, which result ?  Have you a 3DPOLY ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
